Home Forums 4-Cycle Racing Honda GX 160 runs good only with choke 3/4 on
This topic contains 1 reply, has 1 voice, and was last updated by  Ronald Salas 2 years, 4 months ago.
  • #61106
    Ronald Salas
    motor only runs well with choke 3/4 on (3/4 closed)… we’ve tried both a blue printed carb and the stock Honda carb… seems to run a little better with the stock carb but choke still needs to be 3/4 closed… engine has a 32 degree aluminum flywheel… has standard key in it… it ran good before when it was on my other sons cadet kart but after installing it on a jr/sr kart is when it started acting up… really need some advice or comments please…
    ron
    checked for air leaks on carb but found none… ordered two carb gaskets and a jet kit with 8 different jet sizes from OMB warehouse to try those out when they arrive… running lean (needs more gas so a bigger jet opening?)
  • #61604
    Ronald Salas
    replaced the emulsion tube with one with 40% more fuel pick up from OMB warehouse and now finding the right jet (gonna try .37) and hope it does the trick… getting there…
    installed new air filter intake/adaptor from ARC Racing… should let more air in but still running rich now with a .40 jet… gonna try the .37 again… wish me luck
