Home Forums Briggs & Stratton 4-Cycle Racing Briggs LO206 Hilliard Fury on TonyKart 401s
This topic contains 3 replies, has 3 voices, and was last updated by  William Weiler 1 year ago.
  • #83100
    William Weiler
    My builder gave me a 14t gear with a 57 sprocket and it is geared way too low. So I decided to try and go up a tooth in the gear. He built this Kart with a complete used engine and didn’t even know what the clutch was when I asked. I finally identified my clutch as a Hilliard Fury with an accessory clutch bell with the gear mounted outboard, instead of the stock inboard bell. The bell has the gear welded on. I think this arrangement gets the LO206 drivetrain to fit the TonyKart with my XL seat. I don’t know how to modify this to a larger gear. Maybe it’s better to start from scratch. Can someone recommend a clutch that will fit a TonyKart 401s and a XL Tillet seat?
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
  • #83101
    Morgan Schuler
    Cambrian Go Karts (www.cambriangokarts.com) could probably help you out. You need to find a shop or somebody at the track that will help you better.
    If you’re not on Facebook you should join just for the various LO206 groups: “West Coast Briggs 206 Racing” and “Briggs LO 206 Racers” are a couple. You’ll get answers faster on there.
  • #83117
    FREDDY SANDOVAL
    Yes, just start from scratch, that engine may be getting tired, besides it leaks oil, and it seems to have a few issues.
    I have a brand new complete package, with everything you need to just bolt on and go, and with a mount that you can adjust however you want, Plus I will set up for the correct clutch driver gear, and rear sprocket. And carb/float adjustments.
    I tell you, it is kind of nice to know you are the one guy that was doing the engine break-in process.
    We are going to CalSpeed tomorrow. Interested?
  • #84276
    William Weiler
    I bought an impact wrench and took off the clutch bell. Research on the Internet showed is a Bully conversion, so I was able to order the Bully gears. Ironically, the gearing was okay at 14t/57t for practicing at Blue Max in Davis, but still too low for Atwater. I got a 15t/57t, still too low, so I am trying a 16t next week.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
