--> Hilliard Flame Clutch – ekartingnews
Home Forums General Karting Discussion Hilliard Flame Clutch
This topic contains 2 replies, has 3 voices, and was last updated by  Walt Gifford 1 year, 11 months ago.
  • #66925
    monger
    I recently built a Kart for my Kids. I’m currently running a Predator 212 CC 6.5 hp with a Hilliard Flame clutch with a 35 chain. The clutch has a 14 tooth sprocket, with a 72 axle sprocket. After about 20 min’s of running I measured the clutch drum at approx 250 degrees.
    My question- What is the normal operation temp for this? If this is too much, how can I alleviate it?
    any help with this would be greatly appreciated.
    Henry
  • #66937
    Henry,
    You could call TS Racing in Bushnell, Florida, since they are listed as a dealer for that clutch. They probably have the information you need.
    If you’re not using this kart on a track, you can expect to generate more heat in the clutch because it’s spending more time slipping. Try lowering the engagement rpm to keep the clutch locked up more. Less slippage should lower the temp. How much? Couldn’t tell you. I’ve never checked the temperature of a clutch when it comes off the track. It’s hot and I respect that.
    Good luck and enjoy the time with your kids.
  • #66943
    You could put a 12t on the clutch and/or a bigger rear gear and it should be set to the lowest lock up for yard use. 250 after 20 min don’t sound too bad.
