Home Forums Chassis & Handling Help!!! Converting my sons rear bumper to plastic
This topic contains 1 reply, has 2 voices, and was last updated by  FREDDY SANDOVAL 3 years, 10 months ago.
  • #26844
    Joseph Ware
    My son has a 28mm crg kid kart and the steel bumper had to go. I need help with pictures or video to get these brackets on to get this mounted.  Please let me know. You can also email me at bimmer1109@yahoo.com. Its his first season and want him same. I got all the hardware just cannot figure out how to make bushing go into the frame
    Hi, Adam
    The installation is pretty easy, you can use the same bushings inside the frame
    All you have to do is remove the old bumper by removing the big allen bolt,  install the new style bracket with the flat part towards the rear ( you may need to buy new longger bolts to reach all the way inside the frame rails
    Once you determine the length then tighten the bolts but leave them lose enough so that you can turn the brackets to align with the brackets that attach to the plastic bumper
    Once you know it’s gonna fit, the go into town and torque it for good
    Slide the bumper brackets inside the bumper asy, then put the bolt and washers in the bumper to secure.
    Install bumper to frame rail brackets, and leave them snug, NOT TIGHT AT ALL, you need play, it needs to be lose for flexibility.
    You’re done, I hope this helps.
