--> Heat Cycles – ekartingnews
Home Forums General Karting Discussion Heat Cycles
This topic contains 1 reply, has 2 voices, and was last updated by  TJ Koyen 8 months ago.
  • #85776
    William Weiler
    I have a tire question.
    For Evinco Blues on an LO206 Kart, is there a guideline for how many heat cycles the tires can endure before they drop off in performance?
    For practicing, is it better to do more laps in a session, to reduce heat cycles, than to do many sessions with fewer laps?
  • #86080
    Generally, all tires will drop off after the first heat cycle and for every heat cycle after. Some more than others. I don’t have experience with the Evinco Blues but even tires on the harder end of the spectrum tend to lose a bit of performance after the first heat cycle.
