Home Forums Chassis & Handling Has anybody tried these camber/caster adjusters?
This topic contains 7 replies, has 6 voices, and was last updated by  Brett Clatt 3 years, 3 months ago.
  • #44586
    Brett Clatt
  • #44589
    Michael Zahorski
    My daughter’s CRG has them on it and I believe the CRGs are starting to come with it. Even though they are on there, I haven’t adjusted them since I bought it as a one event kart and the kart ran at the SuperNats in Vegas. But they look very easy to adjust and easy to independently adjust camber and caster.
  • #44591
    Gary Lawson
    I’ve worked on a couple margays that have them and they crack where they bolt to the frame. I prefer using a standard pill setup. I used to think independent adjustment was a necessity but it’s simply not critical.
  • #44598
    Rick Brown
    I Love them and haven’t had any issues
  • #44747
    Brett Clatt
    Thanks guys for the feedback.
    • #44966
      Curtis Cooksey
      Independent adjustment isn’t a necessity but it sure makes fine tuning your front end easy. They crack if you tighten them down before the teeth on the castor adjustment are aligned right. If you make sure the teeth are aligned correctly before you tighten them down you won’t have any problems.
  • #44982
    Bill Angel
    We have been using them on
    Margays for a couple of years and I like being able to adjust caster and camber independently. I cracked a couple before I learned to make sure everything free and aligned prior to adjusting and then tightening it back down. Having said that I would pay the extra $ for a machined steel top plate rather than the cast plate Sniper is using.
  • #45073
    Brett Clatt
    Do the holes still have to be opened up to 22mm on newer karts to install these?
