Home Forums TaG Rotax Max Ground wire question
This topic contains 1 reply, has 2 voices, and was last updated by  Christian Fox 2 years, 4 months ago.
  • #61243
    Tom Sabiel
    I am installing a rotax for the first time which has the EVO upgrade kit but not the brand new harness and bracket they are just releasing as I am not entitled to the free upgrades. Where do the 2 ground wires on the engine side connect two as the ends are 2 different sizes ?  Also should the extra connector that is not used on the minimax just be secured to the frame with zip ties?
    Thanks in advance.
  • #61318
    Christian Fox
    Hi Tom, assuming you are not wiring a DD2, there is only one ground wire to be dealt with (the long one). The longer of the two wires attaches to back, inside cylinder head nut. Be sure when you attach it to make sure there is no tension on the wire. Give it as much of a loop as possible and be sure to zip tie it to the bracket so it can’t swing around, other wise it can break and ruin your day. The new harness grounds to the bracket itself, which is a big improvement. And yes, the unused wires can just be ties or taped back.
