Home Forums Tech Talk gp traction control
This topic contains 9 replies, has 6 voices, and was last updated by  Chris Reinhardt 4 years, 6 months ago.
  • #22657
    Rick Brown
    What do you guys think of gp’s new traction control setup? will it work and how does it work?
  • #22811
    Rick Brown
  • #22812
    Rick Brown
    I’m thinking it would work kind of like the front torsion bar. The more you tighten the jam nuts it acts like making the waiste of the kart wider (less flex) am I way off? If it works you could adapt this to any kart pretty easily.
  • #22843
    Rick,
    Can’t see that rod acting as a torque tube.  It has a heim joint on both ends.  Guessing that it could only be keeping the distance between the front tab and the rear tab at the same distance.  Maybe it’s designed to keep the rear end of the kart alinged with the front during hard acceleration out of a corner.
  • #22860
    Rick Brown
    I couldn’t tell if that’s actually a heim or looks like one? Do you think that a chassis can torque enough to miss align from and rear alignment?
  • #22874
    William Martin
    The front connection looks like a Heim joint, but the rear is maybe some kind of compressible thing. So if that’s the case, it’s tuning the front flex…I think. Like making the tubing stiffer in the waist area. Or something :-)
  • #24948
    Peter Zambos
    Let’s see.  Most karters lament that karts are getting overly complicated.  For the most part, I agree.  So, regardless of whether or not it works, I’d rather not see it gain wide acceptance.
  • #25507
    Two tie rods and handle to tighten them is complicated?  If it’s effective, sounds like one the easiest adjustments you can make….
    CR
    XV Racing Products
    http://www.xvengineering.com/
  • #22925
    Might help under heavy braking if you have front brakes. It would also help the front not to flex back only up and down. Weather that helps anything I don’t know. With two joints it could be said to be a moveable chassis component. Might need them on the rear axle with a bearing on one end lol.
  • #25510
    Might help under heavy braking if you have front brakes. It would also help the front not to flex back only up and down. Weather that helps anything I don’t know. With two joints it could be said to be a moveable chassis component. Might need them on the rear axle with a bearing on one end lol. Gif
    They both look like Heims to me…  There would be very little deflection rigidity on a 12mm aluminum rod…  What happens when a corner is deflected upward, the distance from that rear point is increased.  That handle at the back has a set screw at the top.  It looks like they can limit the amount each corner deflects with that adjustment.  It’s working like the front torsion bar, but can be micro tuned…..
    CR
    XV Racing Products
