Home Forums Chassis & Handling Getting Birel R32 steering column centered
This topic contains 8 replies, has 5 voices, and was last updated by  Steve Libretto 4 years, 10 months ago.
  • #4539
    Cosmin Negul
    Hi everyone, I am new to karting and got myself into an R32ST. I’ve changed the nylon support than holds the steering column and the uniball bearing at the bottom, but now I can not get the column to line up perfectly with the uniball. It is slightly off, causing it to bind when I put it in the uniball bearing.
    Can anyone help with instructions on how to adjust the 2 brackets on each side of the nylon holder in order to center the steering column?
  • #4545
    Stephen barthelmass
    it sounds like eitheryour tightening the bolt on the bottom of the steering shaft too tight. You have a bent steering shaft or a seized uniball bearing.  If the steering shaft is hitting the uniball housing when turning the wheel then something is definitely bent.
  • #4550
    Troy V Smith
    Typically, I would install the uni-ball end first, then set and tighten up the nylon bushing.   If your column is tight in the uni-ball, you should have plenty of “free motion”, in the shaft to line it up with the bushings up top (as Stephen says – as long as the uni-ball isn’t junk).  I would think you’d see a bend in the steering shaft if it were bent, but sounds like your best bet is to loosen up everything, and set it all in place without tightening things up.  Get everything lined up and free – then try tightening it up from there.  See how that goes for you…
  • #4556
    Cosmin Negul
    Thanks for the responses guys. To elaborate a bit more, nothing is tightened at this point, nylon and uniball are both new. Steering column is not bent as everything was lined up before I took it all apart. Here are some pictures to help clear things up: http://imgur.com/a/boazf
    As you can see the column is aligned a bit left of the uniball, making it sit at an angle if I put it inside the uniball, causing it to bind on the left side of the nylon. Hope that makes sense.
    Thanks again for your help.
  • #4558
    Benn Herr
    Cosmin,
    You will need to put a slight bend on the two steering uprights. The right side back a little and the left side forward. It won’t take much – just enough to get the end of the shaft pointed at the uniball.
  • #4564
    Troy V Smith
    Yep, pictures are worth a lot.  Guess I’d do exactly what Benn is thinking.  Seems odd that the uprights would require a tweak, but the column may have been in an “unknown” bind before you pulled it out – This leads me to wonder why you had to change the uni-ball and bushing in the first place – were they worn?
  • #4568
    Cosmin Negul
    Uniball had a lot of play in it, I thought the nylon also had play due to being worn but it turns out it isn’t supposed to be tight on the shaft. I’m learning.
    Once I loosened everything and started moving the clamps off the uprights the column started binding up. I marked the position of the clamps and put everything back together but I wasn’t able to find the position in which everything lined up smoothly.
    I will try what Benn suggested and will report back. Thanks
  • #4678
    Cosmin Negul
    I did what Benn suggested and it worked out great. Took very little to get the uprights in the correct position again.
    Everything is back together with fresh parts. There is still play in the shaf at the nylon. Is this normal? Also, I added a locking collar under the nylon since it was missing, is there normally another collar on top as well?
    Thanks everyone.
  • #5289
    Steve Libretto
    Cosmin,
    You may want to loosen the pinch bolts on the support that holds the nylon also. It looks like it is cocked a bit with the right side being higher then the left. Could just be the way I’m looking at the pictures, but I would at least check to make sure it level.
