--> gear shift lever options – ekartingnews
Home Forums Shifter Karts gear shift lever options
This topic contains 1 reply, has 2 voices, and was last updated by  FREDDY SANDOVAL 2 years, 1 month ago.
  • #62973
    Jack Cook
    I just switched to Tony kart for my shifter. i am finding I do not like to location of the gear shift lever, it is to low for my liking. I was using a CRG and found that lever better to my liking. My question is are there any options for the tony kart shift lever.
  • #62981
    FREDDY SANDOVAL
    Can you post some pictures of your set up?
    That way we can understand better about your issue.
    Is it the height from steering shaft? ( vertical)
    Or forward to back? (too far from steering wheel)
    If it’s the height of steering wheel, you can just trim the steering shaft at the top, where the hub goes, and just drill a new hole.
    But if the shifter lever is too far back, then install a longer rod.
    You may also need a 10 or 15 degree angle/wedge foe your steering hub.
    Anyhow, hope that helps. FastFreddy.
