Home Forums Tech Talk Gas Leak During Transport
This topic contains 1 reply, has 2 voices, and was last updated by  tony zambos 4 years ago.
  • #18749
    Justin Paxton
    I have gas that leaks out of the hole at the bottom of my air cleaner when I am transporting the kart to and from the track on my Rotax F125 MAX.  It is coming from the carburetor intake and soaks the foam inside as well.  What is the best way I can stop this from occurring?   Should I be draining the fuel tank prior to departure?  Drain the carb float bowl by turning it upside down?  Both?
    #18775
    For now-BOTH!.  Assuming that you are transporting the kart horizontally, this should not be happening unless pressure is building up in the tank.  Pull the carb off. Check for the floats being installed properly and there isn’t any fluid in them.  The “alto” stamped on the floats should be facing up when the carb is in its operating position. You should be able to hear them rattle when you shake the carb up & down. Also check the needle valve for debris that could be preventing from shutting the fuel supply off or maybe the needle and seat just needs to be replaced do to wear and age.
