This topic contains 1 reply, has 2 voices, and was last updated by  John Matthews 3 years, 9 months ago.
  • #25465
    david buck
    I have access to a complete LO206 that has worn Cam. I am thinking about breaking it open and using it to build the Animal to race IKF.
    I see/hear the difference is the connecting rod, cam, ignition, carb jetting. Can anyone tell me if there are more differences (valves, springs, piston, crank…..)? Should I junk everything but the case and head and replace everything?
    #25556
    The LO206 should be a great start for this. The WKA rules are here, hopefully the IKF rules aren’t too different but if they are let me know:
    http://worldkarting.com/downloads/Section_705%20Pro%20Gas%20Gold%20Cup.pdf
    Of course you will have to change the coil. I would go with a billet rod since the rules allow, and you have to run the spec cam. Other than that it should be a fairly straightforward rebuild.
    Just inspect everything else and replace what you have to. It’s supposed to be an economical class I think so I wouldn’t go overboard trying to get the last little bit from the engine.
    Good luck and let us know how it works out.
    John
