Home Forums Classifieds Classifieds – Parts FS: 40 mm axle gears
This topic contains 2 replies, has 2 voices, and was last updated by  William Martin 3 years, 6 months ago.
  • #30224
    Tom Birchard
    View pictures at:
    http://bit.ly/hcr125p
    http://bit.ly/kwheels
    http://bit.ly/kparts125
    40 mm axle alignment plates – aluminium
    40 mm split axle gears – aluminum
    27, 27, 25, 20, 24, 24, 28, 27
    40 mm split axle gears – steel
    30, 30, 29, 29, 28, 27, 27, 27, 26, 26, 26, 25, 24, 23, 23, 22, 22, 23, 21, 21
    IAME clutch removal tool 10270
    IAME clutch housing new with used 16-tooth gear
    Honda CR125 Drive sprockets
    19, 18, 17, 15, 14, 13
    40 mm hubs
    Gold120 mm
    Black120 mm
    Black70 mm
    Front hubs for brake conversion
    TaG water pump and 40 mm drive hub
    Rear frame stiffener – 30 and 32 mm frame attachments
    Honda CR125 cylinder – ported for shifter kart
    Fresh Nikasil plating
    Power ports are blocked off
    No idea who did the porting
    Aluminum is pitted from cleaning prior to plating
    Good spare/back-up or try your hand at porting
    Airfilter
    F – 2.25”
    FA – 0 degrees
    FL – 1.75”
    L – 6”
    D – 5.25”
    D’ – 6”
    #30480
    Tom Birchard
    PLEASE, someone buy these 428 gears for a 40 mm axle shifter kart!  I really don’t want to take them to the recycling center.  Thanks.  –Tom
    #30511
    William Martin
    Not such popular stuff these days…maybe you could post some prices?
