Home Forums Classifieds Classifieds – Kart Packages FOR SALE: Price Reduced 2004CRG Kali 100 w/ Rotax FR125 Max Senior Motor &Spares
This topic contains 3 replies, has 1 voice, and was last updated by  Shawn Kozlowicz 3 years, 1 month ago.
  • #54803
    Shawn Kozlowicz
    Kart was campaigned in Sprint and Road racing from 2005 through 2009 race seasons winning ASA Proautosport Championships in 2007, 2008, and 2009 with countless podium finishes.
     2004 CRG Kali 100 Chassis with Billet Peddles. Aim Steering Wheel, Mychron 4 (RPM, Temperature, Lap Time) and Ribtech Carbon Seat.
    Chassis Spares:
     Edwards Magnesium Wheels (2 Sets)
     Azusa Aluminum Wheels (1 Set)
     Wheel Studs and Nuts
     9L Fuel Tank
     Three Shockwave 40mm Axles (Soft, Medium, Hard)
     Left Nerf Bar
     Rear Bumper
     Front Lower Nerf Bar
     Bodywork (1 Set)
     Brake Rod and Cable
     Tie Rod
     Lead Weights
     Rear Axle Bearing Cassettes (3)
     Rear Axle 40mm Bearings (3)
     Front Hubs — Long and Medium
     Rear Hubs — Short and Medium
     Spindle Bearings (2)
     Hub Bearings (6)
     Brake Caliper
     Brake Pads
     Two FR125 Max Senior Engines:
    Rotax FR125 Max Senior Engine S/N 785354 (Needs Internal Water Pump Replaced)
    Rotax FR125 Max Senior Engine S/N 184224 without Exhaust, Battery, Charger (Needs Rebuild)
    Engine Spares:
     Fuel Pump
     Power Valve Assembly
     Exhaust Springs
     Reed
     Carburetor Needles (Two K27, Two K98)
     Drive Sprockets
    11T (2)
    12T (2)
    13T (1)
    14T (3)
    15T (1)
    16T (1)
     Axle Sprockets
    65 (1)
    66 (2)
    67 (2)
    68 (2)
    69 (2)
    71 (2)
    72 (2)
    73 (2)
    74 (2)
    75 (2)
    76 (2)
    77 (2)
    78 (4)
    79 (2)
    80 (2)
    81 (2)
    82 (2)
    83 (1)
    87 (1)
    88(1)
     Throttle Cable
     Exhaust Perf Tube
     Exhaust Packing
     Exhaust Brackets
     Ignition Switch
     Starter Switch
     Clutch Repair Kits (3)
     Clutch Drum (1)
     Starter
     Spark Plugs
    Denso IW24 (2)
    Denso IW27 (2)
    Denso IW29 (2)
    Denso IW31 (2)
    Denso IW34 (2)
     219 O-Ring Chains
    102L (2)
    104L (1)
    108L (1)
    110L (1)
    Support Equipment:
     Andersen Professional Pit Kart with Optional Air Tank
     T-handle Hex Wrenches
     Ratcheting Combination Wrenches
     Safety Wire Pliers
     .032 Safety Wire
     Exhaust Spring Installation Tool
     RLV 219 Chain Breaker
     Piston Stop
     Rotax Clutch Puller
     Power Valve Bellow Spring Installation Tool
     Drive Gear Fixture
     RLV Bead Breaker
     Wheel Balancer
     Odenthal Exac-Toe2 Alignment Fixture
     R3 Racing Sprocket Laser Alignment Tool
     Dellorto Carburetor Tools
     Race Jet II Weather Pod
     AMB Tranx160 Transponder
     Aim IR Timing Becon
     Sparco Kart Cover
     Longacre 0-30psi Tire Pressure Gauge
     Robic SC-554 Chrono with Clip Board
     Funnel
     Ratio Rite Measuring Cup
     VholdR Helmet Camera
     Scribner Engine Crate
     Tri-flow Lubricant
     Bel-Ray Chain Lube
     Miscellaneous Hardware
    – (Was $4200), Price Reduced to $3200 Tucson Arizona
  • #54808
    Shawn Kozlowicz
  • #54870
    Shawn Kozlowicz
  • #55491
    Shawn Kozlowicz
    Reducing price to $3200.
