--> FLOOR PAN BOLT ? – ekartingnews
Home Forums General Karting Discussion FLOOR PAN BOLT ?
This topic contains 2 replies, has 3 voices, and was last updated by  Walt Gifford 2 years, 5 months ago.
  • #57183
    Tom Sabiel
    Is there a reason that button head allen bolts are not used from the bottom pointing up to hold the floor pan on so that the nuts are not ground off. We did this years ago and was wondering why this changed.
    Thank you
  • #57186
    Tim Koyen
    Some people still do this.  I guess its different by manufacturer.
    KartLift Kart Stands
    DeepSeat Kart Seats
    877-777-8020
  • #57209
    It should be a safety rule that the heads must be on the bottom. Anyone with common sense and a conscience will do it that way. No need for anyone to get run over with a cheese grater.
