Home Forums Shifter Karts Float setting on VHSH 30
This topic contains 2 replies, has 2 voices, and was last updated by  Rod Balding 1 year, 7 months ago.
  • #67145
    Rod Balding
    I’m needing the stock float setting for a Dellorto VHSH 30 for a stock TM K9c , it has the 1 piece floats and also where to measure (from carb body to top of the floats ?) . I just want to get it set right for a stock set-up .
    THANKS
    #67198
    Steen Carstensen
    Take the float bowl off, turn the carb upside down, and the part of the floats closest to the the carb, should be parallel to the bottom of the carb body. That’s the stock setting, you can then change to what you may prefer.
    #67203
    Rod Balding
    Thanks Steen , that’s the way it was set , but it’s kind of hard to do with needle with the spring in it .
