Home Forums TaG Rotax Max EVO upgrades with no rev!!!!
This topic contains 6 replies, has 5 voices, and was last updated by  Samir Shah 3 years, 5 months ago.
  • #48165
    Jesper Beyer
    Hi everyone..
    Just fitted my 2015 EVO upgrade , harnes, carb, ignition…
    Runs smoothly all they way up to 8600rpm then it stops ( like a rev limiter)
    When I check the PV it closes about 3000rpm and stays closed all the time….
    I have fitted the New carb and jettet it like I’m used to,  with 188/190jets,  is this too big in the EVO carb??!?
    Anyone got some info please repl….
  • #48168
    Daniel Harlin
    Hi, I use a different set of jets and have not seen the same error. In Sweden we use jets between 125-130.
    On the other hand I have seen reports in Europe about some faults with the eRave module which there will be some update for in coming month.
    Hopefully this can help you.
    Daniel
  • #48199
    Mark Traylor
    188-190?  Is this a DD2?  I used to run a 150 in my old senior.   with Evo people are down around 120 on the main for senior and around a 130 in DD2.   The carburation is very different.
  • #48200
    Mark Traylor
    BTW…there have been issues with the PV.  check the bulletins for changes
  • #48207
    Jesper Beyer
    Tried with the 145 jet that followed with the carb and that made a huge difference,  now it rev past 12500 …. I’m just used to jetting my old carb 185 – 192 , think I need to purchase a 110-165 set now ;)
    • #48212
      Bruce Woodrow
      Jesper,
      You’ll probably find that you will need jets in the 130 – 145 range for most conditions.
      Bruce
  • #50509
    Samir Shah
    On my Leopard, I found that if I ran it rich, and fouled the plug, on the next session I could not rev over 7000-8000. Cleaning the plug with brake cleaner and a wire brush usually fixes it.
    Reading through old messages, on the Rotax, if its too rich, there is also a 12k limit that some people have hit, and fixed by using a smaller jet that allowed them to get to 13-14k.
    So, as people have suggested, the problem is certainly jetting, possible compounded by a fouled plug.
    Samir.
