Home Forums Tech Talk Euro Brakes
This topic contains 5 replies, has 3 voices, and was last updated by  Alan Russell 6 months, 1 week ago.
  • #89564
    Alan Russell
    I have an older Birel brakes, non-hybrid.  Calipers B-132×2 Master 10.6406.00.
    My brake lines are shot, leaky.  Any idea what I can do for replacements.  Will anything from MCP bolt up?  The system has one line from the master splitting with a T near the caliper.  Hose lengths are 19″ 3/4, 7″ 7/16, and 11″ 7/8.
    I know they are really metric, guessing 500mm, 190mm, 300mm.
  • #89566
    andy graham
    Let me see what’s in the shed, I think Ive got u covered…. Ive got a bunch of older birel brake stuff …. send me a text, I can reply with some pics
    Andy
    nine oh four 3 four 9 six zero one 3
  • #89569
    Alan Russell
    Awesome.  Thanks.
  • #89626
    Alan Russell
    Does anyone know what the thread is on euro (like birel ) master cylinders and calipers.  1/8 male pipe threads in, so I am guessing it is M10 x1.0.  My thought is to get a 1/8 tap, retap the MC and calipers, and then go to -3 AN brake lines, which seem to be quite easily available.  I’m just a little worried road racing with old brake lines.
    What does one use for thread sealant on brake lines?
  • #89922
    Alan, if you use a pipe tap make sure the threads on the fitting don’t shank out. You want the fitting to tighten up with most of the threads in the block but some thread showing. If you need sealer it’s not tapped right but teflon paste is ok.
  • #89956
    Alan Russell
    Thanks Gif.  I’m just going to dump some data in here for the next person trying to do this.
    I ended up using Permatex 59235 High Temperature Thread Sealant on the threads.  Instead of going to braided steel covered lines I just bought Speedway’s Lightweight Nylon Racing Brake Line Kit.
    To rebuild the master cylinder since I have a 22b pump (22mm/ 7/8″ bore) I bought wheel cylinder cups from napa (this is what it used originally) part# UP 3023 .  If it was a 19b pump (19mm/ 3/4″ bore) you would need part# UP 4158.
    To rebuild the calipers you need 1 1/4″ wheel cylinder cups, part# UP 666.
    These wheel cylinder cup part #’s are all NAPA specific.  To find these parts on NAPA’s website is difficult.  Try this link.
    https://www.napaonline.com/en/search?text=wheel%2Bcylinder%2Bcup&q=Ntk%3DKeyword%26N%3D0%26Ntt%3Dwheel+cylinder+cup&isProduct=true&page=1
    Most of these parts are for cars made in the 40’s…  So pick up spares when you pick them up.
