--> Engine Parts – TM, Rotax, Dell'Orto, Keihin, Mikuni, SwedeTech – ekartingnews
Home Forums EKN Kart Mall Engine Parts – TM, Rotax, Dell'Orto, Keihin, Mikuni, SwedeTech
This topic contains 5 replies, has 2 voices, and was last updated by  Rod Balding 4 years, 2 months ago.
  • #22733
    Jason Berry
    TM K9C SwedeTech Blueprinted Cylinder – Replated and port clean up done by SwedeTech – Has not been run since. ..$700.00
    SOLD **2   New – Packing mat ICC Silencer … SOLD
    1   Used – DellOrto PHSB 38 LD
    1   Used – Dellorto VHSH 30 CS – No Top …$100.00
    1   Used – Dellorto VHSH 30 CS complete. …$130.00
    1   Used – Dellortor VHSB 39 ND (stamping is shallow)
    1   New – SKM 428 50mm Rear sprocket 26T …$50.00
    1   New – SKM 428 50mm Rear sprocket 28T. …$50.00
    2   USED – SKM 428 50mm Rear sprocket 23T… $25.00
    2   USED – SKM 428 50mm Rear sprocket 26T … $25.00
    2   USED – SKM 428 50mm Rear sprocket 24T … $25.00
    2   USED – SKM 428 50mm Rear sprocket 25T … $25.00
    2   USED – SKM 428 50mm Rear sprocket 27T … $25.00
    2   New – Mikuni MKDF52 Fuel Pump (Round, dual out, single in)…$20.00
    SOLD  ** 1   Used TM JET Kit with Billet Holder, 6 Nozzles and assorted main jets and pilots
    1   NEW – 428 CR125 Front 17T…$10.00
    1   NEW – 428 YZ125 Front 17T…$10.00
    2   New – TM Clutch Pack – Fibers, ALuminum floaters, springs…$80.00
    1   Used – TM Clutch Pack – No Springs $30.00
    1   New – TM Clutch Pack – No Springs $65.00
    4   New – OEM TM Steel Clutch Plate $5.00
    1   New – TM Gasket Kit #05612…$20.00
    1   New – SwedeTech TM K9 Reeds only..$60.00
    1   New – SwedeTech TM K9 Reed set with stiffeners…$70.00
    1   New – TM K9 Reed Set with Stiffeners (Carbon Fiber)$70.00
    1   Used – SwedeTech TM K9 Reed set $40.00
    2   Used – TM ICC 15t $15.00
    3   Used – TM ICC 16t $15.00
    3   Used – TM ICC 17T $15.00
    1   Used – TM ICC 18T $15.00
    1   New – TM ICC 19T $15.00
    1   New – Thermostat Righetti Ridolfi #K696N
    ** SOLD ** 2   New – TM Piston Kit with Bearing – 53.94.. $100.00 ** SOLD **
  • #23611
    Jason Berry
    Some items sold.  See updated list above.
  • #23655
    Rod Balding
    PM sent on Mikuni fuel pumps
  • #23693
    Jason Berry
    Mikuni Pumps Sold
  • #23874
    Rod Balding
    Thanks Jason for the quick service , the pumps are perfect .
    RB
  • #23061
    Jason Berry
    <span style=”line-height: 1.5em;”> </span>
