Home Forums Chassis & Handling Dumb Floorpan Question
This topic contains 2 replies, has 3 voices, and was last updated by  Gary Lawson 2 years, 7 months ago.
  • #56537
    Richard Gordon
    which side of the frame tabs should the floor pan be mounted on?  On top of the tabs or under them?  Got a new kart that has the pan on top and a used one that has it on the bottom.  Have to replace the pan on the used one since it is cracked and didn’t know if it was mounted correctly or not?
  • #56538
    Jim Howe
    I have mine with the floorpan on top of the tabs. That way if any of the bolts come loose from vibration, the driver isn’t gonna fall through.
  • #56540
    Gary Lawson
    Just depends on manufacturer. Some are above tabs on all. Others are on top in front and bottom of rest. If it fits above without any issue then that’s where I’d run it.
