--> dsm front wheels:pro/con – ekartingnews
Home Forums Chassis & Handling dsm front wheels:pro/con
This topic contains 2 replies, has 3 voices, and was last updated by  TJ Koyen 2 years, 2 months ago.
  • #60624
    Lou Pirro
    In the interest of total disclosure I am a total nube. If my questions seem dumb, remember I am only trying to learn.
    I recently bought a ptk cart that I plan to autocross (solo) with the Mohawk-Hudson SCCA. The kart has dsm front wheels,so my question is what are the benefits and draw backs verse hub mounted front wheels.
    Thanks,Lou
  • #60659
    Richard Gordon
    Not much other than you can make the front track width wider than with dsm. Might be a big advantage for certain tires and engine combos.  Also might be a little stiffer with less flex going on.
  • #60662
    Exactly as Richard said. You can get a wider front track with hub mount wheels, and the hub stiffens the front spindle slightly, both resulting in more front grip and more weight jacking.
