Home Forums Classifieds Classifieds – Kart Packages Dec. 2015 Daytona B-Stock Winning Kart
This topic contains 1 reply, has 2 voices, and was last updated by  Mike Peters 1 year, 4 months ago.
  • #83677
    Mark J Schoonover
    Ricky Fulks won Daytona with this kart in December 2015. His fastest lap was 2:00.804. 10 laps in the 2:01’s. 8 laps in the 2:02’s. 3 laps (end of race) in the 2:03’s.
    This 2008 Margay/Fox Valley Dual has been raced with success by Milo J Schoonover, Randy Fulks, and Ricky Fulks. Built and maintained by Mark J Schoonover of MJS Racing, with modifications by Randy Fulks.
    Some pics
    https://www.dropbox.com/sh/gohjtuinpn2ozw7/AABSL0wthPBFaKD0zcX_ESBga?dl=0
    ROLLER
    No Engines. No Clutches. No Belts.
    Includes:
    Two IR1 pipes. Two S3 pipes. One IR2 pipe.
    Spare set of Daytona wheels and used tires. 6” dia. Front and Rear.
    Set of Short Track wheels and tires. 5” dia. Front scrubbed and new Rears.
    Set of Short Track wheels. 5” dia. 2 fronts and 2 Rears.
    Pair of Metric pattern hubs for rear Short Track wheels.
    Front Enginetic brakes are rebuilt with EP seals for DOT 3 or 4 or 5 fluid.
    Rear Wilwood caliper is rebuilt with new EP o-rings, new pistons and new wear plates.
    Both Enginetic Master Cylinders are rebuilt with EP seals for DOT 3 or 4 or 5 fluid.
    Brake system has Motul RBF 600 DOT 4 fluid.
    New Terry Ives rear brake disc.
    New Pierre Huang’s GOLD Powr Pads front and rear.
    ROLLER $3,000
    ROLLER OPTIONS:
    Spare Digatron DT-54K R2T2 with a spare Beacon Receiver, two Tach Leads, and two EGT Leads. $300
    One set (4) front GOLD Powr Pads- Two sets (4) Rear GOLD Powr Pads – One set (2) Hawk BLUE rear pads. $150
    $100 worth of Wilwood Caliper rebuild parts. $75
    (39) Rear Gears: three 67, three 68, three 69, three 69, three 70, three 71, four 72, four 73, two 74, three 75, three 76, three 77, two 78, two 79.
    $20 each or $530 all 38 gears.
    RIMS:
    Six DWT 707-02 5 ½ x 5 x 2 ½ backspace, American pattern.
    Eight DWT 705-22 7 ¼ x 5 x 2 ½ backspace, American pattern.
    Two DWT 705-18 5 ½ x 5 x 2 backspace, American pattern.
    One DWT 706-04 5 x 6 x 2 ½ backspace, American pattern.
    Two DWT 706-05 6 x 6 x 2 ½ backspace, American pattern.
    Two Burris 6 x 6 x 2 ½ backspace, Metric pattern.
    Rims are $15 each.
    RIMS and TIRES:
    Two 6 x 5 x 2 ½ b.s., Amer, w/scrubbed 11 x 6.00 – 5, SL4’s, $100 pair.
    Two 6 x 5 x 2 ½ b.s., Amer, w/New 11 x 6.00 – 5, SL4’s, $110 pair.
    Four 5 x 6 x 2 ½ b.s., Amer, w/used 11 x 5.00 – 6, RH2’s, $50 pair.
    Two New DWT 746-099 5 ½ x 6 x 2 ½ b.s., Amer, w/New 11 x 5.50 – 6, RH2’s, $125.
    Two 6 x 6 x 2 ½ b.s., Metric, w/New 11 x 5.50 – 6 , RH2’s, $110 pair.
    Two 6 x 6 x 2 ½ b.s., Metric, w/scrubbed 11 x 5.50 – 6, RH2’s, $100 pair.
    Two 6 x 6 x 2 ½ b.s., Metric, w/used 11 x 5.50 – 6, RH2’s, $50 pair.
    Two 6 x 6 x 2 ¼ b.s., Metric, w/ scrubbed 11 x 5.50 – 6, RH2’s, $100 pair.
    NEW TIRES:
    Four 11 x 5.50 – 6, RH2’s, $60 pair.
    CLUTCHES:
    Two 1 ¼ “ SMC Gold Clutches. Serial numbers 4086 and 4087 with black Speed Collars. Rebuilt Jan 2017 with new Discs, new Floaters, and new Springs. Uses TS Racing Clutch Oil. Two new 920 belts and five used 920 belts. Two quarts TS Racing Clutch Oil. 24 brass and 12 lightened brass weights. Plus $80 in spare parts.
    $1500
    CLUTCH OPTIONS:
    Two sets custom machined Primary Clutch weights. Stock Pies and 130 grams. These are 95 grams and are a must for Daytona. Not used at any other track.
    $300
    ENGINES:
    Four PCR-TSL98-4K Engines with coils and fresh carbs.
    Two are fresh rebuilds, with bench break-in time only. 50.40 and 50.34 Pistons.
    Two have the NCM and Daytona races on them. 50.34 and 50.32 Pistons.
    Three New in-box Pistons 50.32, 50.34, 50.40.
    Miscellaneous Gaskets – Cylinder Base Gaskets, Carb Base Gaskets, Exhaust Gaskets, Reed Gage and Manifold Gaskets.
    Some new and used Reeds
    Ten New in-box Autolite 2414 Spark Plugs
    $2500
    ENGINE OPTIONS:
    21 Engine Gears – two 14, three 15, four 16, three 17, two 18, three 19, two 20, two 21.
    $30 each or $500 for all.
    CONTACT:
    Mark J Schoonover (Milo’s dad)
    MJS Racing
    mjsracing@hotmail.com
    262-370-6841 cell
  • #86180
    Mike Peters
    bump
