Home Forums Tech Talk CRG help
This topic contains 21 replies, has 7 voices, and was last updated by  Jimmy McNeil 5 years, 2 months ago.
  • #13436
    Ace Rossi
    Tuning guide states you can raise or lower rear ride height to tighten or loosen up kart.
    My question is, the slotted holes in my 08 road reonly will only allow maybe 1/4 inch either up or down. Is this all there is, or am I doing something wrong?
  • #13452
    Joe Johnson
    The holes are a lot of adjustment.  You will notice big changes from axle up or down.
  • #13453
    Ace Rossi
    Joe I know that moving axle up or down makes a change but my question is, is ALL the adjustment JUST in that 1/4 inch either way? Seems it would be more. The guide says try different holes but looking at mine, by using different holes, the cassettes won’t fit the hither holes, so I’m stuck using just the holes I’ve been!
  • #13455
    Ace Rossi
    Here is a picture showing the mounting holes with very little adjustment! Is this all there is in adjusting up or down?
  • #13456
    Ace Rossi
  • #13476
    Ace, there’s two adjustments for rear ride height, up or down, choose one and try it….
    CR
    XV Racing Products
    http://www.xvengineering.com/
  • #13479
    Ace Rossi
    It’s obvious you guys are missing THE question!
    As seen in the picture, I HAVE moved the axle up  AND  down .
    I know what it’s supposed to do both ways!
    What I’m asking is, is the total adjustment ONLY  a 1/4 inch (if that) up and down?  OR is there a set of another group of holes that I’m not seeing?
    Its a fairly simple question! It’s yes or no and the holes I’m using is ALL the adjustment there is, period!
  • #13481
    I guess you missed the point!!!  That’s IS the adjustment, slotted holes, all up, or all down…..  Are there another set of holes on your brackets?  Then I guess that’s it then….
    CR
    XV Racing Products
  • #13486
    Chris Bany
    Ace – YES, that is the adjustment, very small measurment up or down and it will make a big difference to set up and on track feel.
  • #13492
    Ace Rossi
    Thank you Chris Finally! That’s all I was looking for. A confirmation that Inwasnt overlooking something! I guess I should have asked you in the first place!
    BTW, how those ribs?
  • #13520
    Daryle Redlin
    Sometimes there is a small 6mm hole in the carrier that will line up with a small hole in the actual cassette. This will give you a middle position, however most times you will either race with it up or down.
  • #13561
    I’m surprised non of you seasoned guys know about the hidden ride height adjustment on the 08 CRG shifter chassis.
  • #13563
    Weren’t the 08’s 4 bolt cassettes?  That picture looks to be a 3 bolt?
    CR
    XV Racing Products
  • #13591
    Jimmy McNeil
    Yes the 08’s are four bolt
    Ace, does that chassis have ven05 brakes?
  • #13593
    Ace Rossi
    Jimmy I was told it has ven4 brakes!
  • #13595
    Sounds like you have an 07 at best…..
    CR
    XV Racing Products
  • #13597
    Ace Rossi
    Nope it’s an 08
  • #13622
    I think you missed the point…..again….  The 08’s had 4 bolt cassettes and VEN 05 brakes, yours does not….
    CR
    XV Racing Products
  • #13626
    Ace Rossi
    No point missed but… Whatever!
  • #13667
    Ace Rossi
    It’s all good Jimmie! It is what it is
  • #13668
    Jimmy McNeil
    I hear ya.
    Man it’s tuff posting with my phone.
  • #13665
    Jimmy McNeil
    Ace, if it says 08 on the chassis Id plate, it could still be a 06 or 07.
    Its the homologation period wich I think is three years.
    Forinstance, i think my 2012 chassis says 2014 On the chassis Id plate.
    ive probably owned 9 or 10 2008 road rebels, all have had four bolt cassette and ven05 brakes
