Home Forums Tech Talk CRG brakes dragging
This topic contains 8 replies, has 4 voices, and was last updated by  Steen Carstensen 3 years, 4 months ago.
  • #44127
    Brian Terpstra
    My brake caliper is stamped with 15/16/FR/08.  This is the system with a floating rotor.  When on the stand with the chain off I rotate the axle by hand and can hear the pads dragging slightly against the rotor.  And at a certain point it drags more and will stop the rotation.  The clearance between the pad and rotor is around .001 on one side and less on the other.  How would I go about increasing the spacing on each side?
    Thank you
  • #44159
    Steen Carstensen
    First thing I would do is to check that the lever on the master cylinders go all the way back against the body, when the brake is at rest. Take the rubber cover off and disconnect the brake rod/cable at the lever and adjust the rod if necessary.
  • #44218
    Brian Terpstra
    I double checked to be sure, with the brake rod removed completely there is still a little drag.  How do I back the pads off?
  • #44224
    Steen Carstensen
    You have to work the brake a bit when you are certain the MC lever return all the way.
  • #44235
    FREDDY SANDOVAL
    Install spacers between the caliper halves, you should have more clearance than that, check all the hardware on the rotor and hub.
    Go drive it, or try it on the stand. if it still drags, and the pads are not returning, then you have a hydraulic problem.
    Either the calipers are sticking, or your master is.
    Try that procedure, to narrow it down first. Please post pictures of what you’ve got, so we can help you better. FastFreddy.   ;)
  • #44316
    Brian Terpstra
    I am trying to link a video of the thing turning, not that computer savvy.
    if I were to install a spacer in the caliper, is that a specific part?  Do I make one with some washers?
  • #44318
    FREDDY SANDOVAL
    Your pictures are not uploading successfully here, you have to use a server like facebook, or photo bucket.
    Just send me some pics to my email address, I’ll steer you in the right direction, buddy.
    fastracerfreddy@aol.com
  • #44355
    Jimmy McNeil
    Brian, what year is your Crg? In 08 they switched to ven05 brake system, you can’t  put shims in a ven05 caliper. Not familiar with the ven04 or older.
  • #44368
    Steen Carstensen
    First off, you do NOT shim these brake calibers, they are self adjusting
    From your video, that doesn’t really look that bad.
    First, take off the top cover plate and the rubber insert on the MC, and check that the MC is not overfilled, there is a fill line in the MC reservoir. While that is off, push the rotor against the brake pads, so to move them just a very small amount, do both sides, check fluid level again and adjust if too high. Put it back together and pump the brake a few times using the pedal, make sure the MC lever returns all the way each time. If that doesn’t work, check for run out on the brake carrier.
