--> Cracked Spindle Hanger – eKartingNews
Home Forums Tech Talk Cracked Spindle Hanger
This topic contains 3 replies, has 3 voices, and was last updated by  FREDDY SANDOVAL 2 years, 1 month ago.
  • #65957
    Thomas Salandra
    I cracked my spindle hanger today and I was wondering if there are any companies that will aligned and weld the problem.
    If you know anything please leave a comment or private message me<span style=”-webkit-tap-highlight-color: rgba(0, 0, 0, 0);”>.</span>
  • #65960
    Where is it cracked? Any welding shop could fix it.
  • #65961
    Thomas Salandra
    It is the hanger itself. It is cracked on the connection to the frame and needs to be straightened.
  • #65969
    FREDDY SANDOVAL
    Thomas
    If it’s cracked or broken off at the mounting bracket, Walt is right any welding shop will do, or take it to your local kart shop, or an automotive repair facility with a welder.
    They can mount the caliper and the bolts and make sure they all lign up before they weld to make sure it’s all straight.
    I would recommend the nearest kart shop in your area, but I can’t see where you’re from at your profile. Good luck.
