Home Forums Shifter Karts CR80 Jetting help
This topic contains 3 replies, has 3 voices, and was last updated by  Bob Schabel 3 years, 3 months ago.
  • #34609
    Bob Schabel
    I have a CR 80  modded engine, Mikiuni car, pump around system. 85 degrees F  Need a suggested main jet starting point.
    #34642
    Greg Lindahl
    #34668
    Gary Smith
    Hi Bob,
    Are you running an airbox or a K&N style air filter?
    What altitude are most of your tracks?
    Most of my tracks are about 1,000 feet above sea level, I run a K&N style air filter, I am running a 195 main.
    If you are running an airbox, I would try 190 or 185, I’ve heard go down 2 jet sizes for an airbox.
    What ever you do, check your plug every time you make a jetting change. You are looking for the center insulator being brown to light tan, if it is white or gray, you are too lean.
    Hope this helps.
    Gary
    #55 Honda CR80
    #34672
    Bob Schabel
    thanks, I run  KN style air filter, alt=700ft.   I run a 195-200 in my stock motor. was told by someone for the mod motor needed a 380-360 jet?    So, thanks for the help, I’ll start at 200 and see what the plug tell me. bob
