--> CR250 Pulse Fitting – ekartingnews
Home Forums 250 Superkarts CR250 Pulse Fitting
This topic contains 3 replies, has 3 voices, and was last updated by  Ian Harrison 4 years, 2 months ago.
  • #20157
    On a 2003 CR250 Where is the best place to drill and tap for a fuel pump pulse fitting?
  • #20259
    nigel cooper
    same place as on a cr125,downstream of the reed cage on the side that your pump is going to be on.Whatever happened to your CRF250 kart from a few years ago? You sure did a nice job on it,the pics of it looked great.(I think it was yours?)
  • #20291
    Thanks  I still have it. Forever a work in progress.
  • #20373
    Ian Harrison
    There!!! By far the best place. Drill and tap for an 8mm Time-Sert into the redundant gallery and cross drill into the crank chamber. Then bolt in an 8mm pulse nipple, or you can use a banjo union if desired.
