Home Forums 250 Superkarts CR250 intake reed choices
This topic contains 14 replies, has 4 voices, and was last updated by  Ian Harrison 4 years, 7 months ago.
  • #20674
    nigel cooper
    Can I get some opinions on the choices of reeds that are available for my stock 2001 CR250 sprint shifter kart?
    1)honda stock reeds
    2)boyesen superstock fibre reeds
    3)boyesen superstock carbon reeds
    4)boyesen proseries reeds
    keep in mind this is for a fun-not race application with max rpms not exceeding 9,500
    as per Viper racing helpful instructions
    nc
  • #21553
    I just put together a 2003 CR250 sprint kart. I left the power valves operational. Stock it was a disapointment more than a 125 but not much more. I swapped the stock Mikuni carb for a PWK air striker and swapped the OEM reed for a Boysen RAD. That woke it up a lot.
    So what would be the next logical step to wake it up some more.
  • #21564
    nigel cooper
    thanks for the reply Brian,I chose not to go the RAD valve route,(for now)as I think it will be more than enough HP stock for me to handle I can always change it later.I left in the powervalves as well.Sorry to hear that your not happy with how the project turned out compared to a 125.From my notes on older posts I believe the next step would be replacing the stock Honda ignition module with a Viper racing one.
  • #21569
    Ian Harrison
    Hi Guys
    The early 1986/1987 reed block with the nylon stuffer is probably the best until you get upward of 10,500rpm. The stock Honda reed petals are fine, but this one is fitted with 2-stage Boyesens. Just cut of your inlet rubber level if it has protrusions and shape the stuffer and rubber to blend in nicely. Loads on Ebay
    http://www.ebay.co.uk/itm/Honda-1986-CR250-Reed-Cage-Valve-Reeds-Vintage-oem-CR-250-AHRMA-1-YEAR-ONLY-RACE-/161186479837?pt=Motorcycles_Parts_Accessories&hash=item2587767edd
    The what’s next question is always difficult. Depends on your intended use and where you want to end up.
    Pipe, Ignition, Porting and head
    Best Regards
    Ian :-)
  • #21653
    I’m not finding anything for upgraded ignition for a 2003 seems like the 2001 is readily available but not the 03.
    Nigel it definetly had more power than a 125. The problem was that there was no top end. If you look at the power curve for an 03 it hits around 46 HP @ 8000 RPM after that it really falls off. I never messed with the OEM Mikuni carb so maybe it could have been dialed in and made better but the Air Striker was much better even before it was jetted. I ended up with a 180 main 55 pilot clip in mid position. Between that and the rad valve it really woke up the top end. Now it’s considerably faster than a 125 but not as fast as the CRF450.
  • #21808
    Thanks Chris  I’ll give that a try
  • #21885
    nigel cooper
    that horsepower and rpm seems low.The charts that I have seen on the forum for a mildly tuned 2001 CR250 are 55HP at 9500 and the curve up to that point is quite linear? And with a new box you get another 5hp and another 500 rpm with the same engine.
    How does the kart compare to your CRF250 kart?
  • #21888
    It has more than the the CRF 250 That’s about the same as a stock honda (kart kit). I don’t know if the HP is acurate I’m going by what’s on the net.
    http://www.dirtbikemagazine.com/ME2/dirmod.asp?sid=&nm=&type=Publishing&mod=Publications%3A%3AArticle&mid=8F3A7027421841978F18BE895F87F791&tier=4&id=B3CE309756F740A8B243F4F48F39FA16
  • #21891
    nigel cooper
    If you have the time,and feel like going through the old forum archive,you will find a few dyno curves posted by Ian at Viper,I remember there was one of his race engines and it was 62 hp,32ft/pounds torque,but  I dont recall the max rpm.There just happened to be a curve of an almost stock 2001 cr250 posted which was perfect for me.
  • #21903
    If the bone stock 03 bike engine is 45HP Which seems to be what the bike guys are saying That’s with the OEM Honda pipe. I got my pipe from Mike at Shark Shifter (Knowledgeable helpful guy). Lets assume the kart pipe has no effect on HP. I ran the kart all stock before doing any mods and I don’t have any way of knowing for sure but I think the carb and RAD valve probably added a good 5HP the difference was dramatic. If that’s true then it’s putting out around 50 HP.
    I should probably think about getting rid of the power valves and going with  Ian’s ignition system.
  • #21934
    Ian I don’t think I need the power valve and I don’t have TPS. Do you have an opinion on power out put with the mods I did (RAD valve + PWK Carb) along with your ignition system?  Do you know what the HP is on the stock engine?
    I sent you a PM for price and avaiability of your ignition system.
  • #22102
    Ian Harrison
    Hi Brian
    I would think you should have 50 Hp at present if your not exceeding 9,500. (You can see above that we have 56Hp at 9,500rpm).
    The limiting factors will be compression ratio (too high?), ignition (Too much advance above 9,750 rpm) and pipe (depending on the rpm range and exhaust duration that it’s designed for)
    I do have your mail. I should get to it tomorrow . . . . . Bloody hectic!!
    Apologies to the people who are waiting for product, exhausts, heads, ignitions, etc. I expect to be fully caught up by the end of next week and thank you for your patience. This time of the year is always madness.
    The new engine has taken over my life for the last 6 months, . . . . but we are getting there.
    Best Regards
    Ian
  • #21807
    Let Ian update you, but I remember him talking about the after market ignitions didn’t work well, I believe it was because the stator assemble had a wacky voltage….  Then they bolted on the earlier stator assembly, but the timing had to be offset because the stator plate was timed differently on the two motors.  Then I believe he was swapping the guts from one and putting on the case reed stator plate, so the timing was all good.  At some point he was using some sort of regulator/filter to tame the stator voltage, I’m not sure if that’s what he ended up with or not.
    Bottom line, nobody makes a direct fit after market CDI box for the case reed, at least nothing that works…
    BTW Ignition timing is probably why your hitting a wall..  Try retarding the ignition as far as it will go, and see if the top end improves…
    CR
    XV Racing Products
    http://www.xvengineering.com/
  • #21838
    dupe
    XV Racing Products
  • #21908
    Ian Harrison
    On our race motors, we use the ’01 Honda Generator with Viper HPI box. This is a great race system, but generally speaking, it won’t operate powervalve, powerjet or work with TPS.
    I think we are there now with a system that runs from the ’05-’07 generator. We are testing this year on our own karts. This comes in 2 versions. The first is as above, the second can run with powervalve, powerjet and TPS.
    Here’s a dyno run of one of our CR250’s. It has over-rev to 11,500, but this run is only to 10,900:
    You can zoom in by holding down the Ctrl key and tapping the + key
    Ctrl and 0 (zero) to go back to normal
