Home Forums 250 Superkarts CR250 crank bearings
This topic contains 2 replies, has 2 voices, and was last updated by  nigel cooper 4 years, 3 months ago.
  • #13844
    nigel cooper
    Our bearings supplier that we use at work is having a problem getting me crank bearings.I told him  I need a pair of  unsheilded KOYO 63/28,CS30 bearings with heat treated cages but he is having a problem.Does anyone have the correct Koyo part number? Buying them from Honda will cost me more.
    #13854
    Ian Harrison
    Hi Nigel
    CS30 is an O/E bearing number and only supplied to manufacturers under that reference and not supplied through the bearing resellers. It is a special 2-stroke crankshaft bearing designed to operate in the limited lubrication situation of a 2-stroke engine. It has a special heat-treatment of the bearing cage and specific running clearance.
    Honda Part #: 91008-KAE-731
    Never use the general engineering bearing 63/28 C3 or C4. These get sold a lot on Ebay etc. and you probably get away with it in a crosser.
    But then you knew all that 😉
    Best Regards
    Ian 🙂
    #13856
    nigel cooper
    Thanks again Ian,
    I guess Ill have to get them from honda.Im buying bearings often at work and can get great prices for myself due to the money we spend at our supplier,but I learned from a previous post of yours that the CR250 crank bearings are special and I must have them.(PS. turns out I`ll have to buy a honda crank as well.When I got the engine apart I was shocked to find a Wiseco crank.I was assuming a honda crank and sending it out for rebuilding)oh well,i have all winter
    nc
