--> CR125 clutch lever mechanism? – ekartingnews
Home Forums Shifter Karts CR125 clutch lever mechanism?
This topic contains 7 replies, has 3 voices, and was last updated by  EKN 4 years, 7 months ago.
  • #10574
    nigel cooper
    Have a strange situation with the clutch actuator lever.(The linkage that the cable attaches to).On the web page “How to build a Stock Moto Engine” there is a picture in the Bottom End Reassembly section showing a spring on the lever holding it down,yet the Honda dealer shows no spring,and the replacement lever from Honda does not have a spring included with it
    Again,the picture on the metal-matrix website clearly shows a spring. I am really confused.Hope someone can help.
  • #10575
    Steve Laymon
    I believe the 92 through 96 models called for a Spring and a Thrust washer which rides next to the seal.  I think it can be used in all years if you prefer.
  • #10577
    nigel cooper
    Thanks Steve for the quick reply.I checked it out like you wrote and sure enough,on a 1996 part diagram they show the spring and washer!!Hurray,back to Honda tomorrow to order the parts.I want a spring on my engine.
    thanks again
  • #13729
    EKN
    Keymaster
    Have a strange situation with the clutch actuator lever.(The linkage that the cable attaches to).On the web page “How to build a Stock Moto Engine” there is a picture in the Bottom End Reassembly section showing a spring on the lever holding it down,yet the Honda dealer shows no spring,and the replacement lever from Honda does not have a spring included with it.
    TEST
  • #13730
    EKN
    Keymaster
    TEST 2
    nigel cooper wrote: Have a strange situation with the clutch actuator lever.(The linkage that the cable attaches to).On the web page “How to build a Stock Moto Engine” there is a picture in the Bottom End Reassembly section showing a spring on the lever holding it down,yet the Honda dealer shows no spring,and the replacement lever from Honda does not have a spring included with it.
  • #13731
    EKN
    Keymaster
    TEST 2
  • #13732
    EKN
    Keymaster
    TEST 3
  • #13733
    EKN
    Keymaster
    TEST 4- hyperlink
