--> CR125 Build Questions – ekartingnews
Home Forums 2-Cycle Racing CR125 Build Questions
This topic contains 4 replies, has 3 voices, and was last updated by  John Lafakis 4 years ago.
  • #25114
    John Lafakis
    I’m rebuilding a 99 CR125 and had a question regarding the HPP power valve actuator rod.  I noticed that some engines may have this removed.  Do I need to remove this rod for karting? Also, if I remove the rod do I need to plug the hole?  Pics would be appreciated as I’m having trouble finding any online and I’ve read of plugs made for this purpose.
    Also, what’s the best cylinder hone to use on these, and what should the final measurements be on the cylinder?  The piston overheated and left ring material on the cylinder and I’m trying to salvage it with a hone before I succumb to buying a new cylinder.  Rest of the cylinder is fine with no scoring or cracks as far as I can tell.
    Thank you for any help!
  • #25142
    johnny brooks
    Start here:
    http://www.metal-matrix.com/stockmoto/index.html
    Here’s a follow up to above:
    http://metal-matrix.com/cr125-rebuild/index.html
    Ask your ‘hone’ question in the ‘shifter kart’ thread…’nikasil’ cylinders require careful attention.
  • #25160
    John Lafakis
    Thanks, I’ve seen those before and they are very helpful, but it only briefly covers the removal of the actuator rod.  I’m assuming this is left out for kart racing since all the built engines I have seen are removed.  since the cylinder is in need of repair as it sits I’ll just hit it with a standard hone and hope for the best.  If it ends up going out of spec I’ll just buy a new cylinder or have it sleeved.
  • #25367
    Greg Wright
    Don’t have the cylinder sleeved. There are a number companies such as Millenium Technologies that do a bang up job of refinishing the bore.
    Greg Wright
    Rapid Racing Inc.
    Vintage B-Stock Pilot
  • #25370
    John Lafakis
    I ordered the proper hone for the cylinder, I’ll see if it can be touched up.  If. The hone doesn’t work then I’ll call millenium like you recommended.
    Thank you for the help
