Home Forums Classifieds Classifieds – Parts Comet BP WA55 Carb, PKT Axle, Birel / Freeline stuff
This topic contains 4 replies, has 3 voices, and was last updated by  Juan Morales 1 year, 8 months ago.
  • #43791
    Joey Cruz
    1 – WA55 Comet Blueprinted Small Bore Carb with filter cup and manifold $140
    1 – WA55 Adkins Blueprinted Small Bore Carb with filter cup  $80
    1 – PKT 30mm 1060 3.0 Axle (Brand new) $120
    1 – PKT 30mm 1060 3.0 Axle (Good condition) $75
    2 – Birel / Freeline 30mm Sprocket hubs $20 each
    1 – Pair of Birel / Freeline 30mm rear hubs (45mm) New $40
    1 – Pair of Wildkart Front hubs (17mm spindles) $25
    1  – Pair of Birel / Freeline spindles for 28mm chassis $100
    1 – Cadet Pedal Box $50
    1 – Birel / Freeline front wheel (DSM 17mm) $25
    1 – Set of Birel / Freeline wheels 130mm (DSM front / hub mounted rears) in chrome $100
    PM with questions and anything else you need. Pictures can be seen at:
    http://s744.photobucket.com/user/need4speed23/library/Sportsman%20Parts?sort=3&page=1
  • #44696
    Samir Shah
    Hi. Any part numbers or specifications on the spindles? Thanks.
  • #44807
    Joey Cruz
    Spindles are originally for Birel AR28 and C28 chassis, however they might work with other cadet chassis.
    10 degree with 8mm kingpin bolt.
  • #75527
    Juan Morales
    Hi, I am interested in the wildkart front hubs.
    Are these for the European bolt pattern wheel?
    thanks,
