Comer parts, both new and used parts, two Comer 50 engine blocks, and enough stuff to build two motors.
NEW in theBOX: Needle Bearing
, 4 Dual Row bearings, 2 Single row bearing, 1 Drum bearing, 25 set base gasket set, Clutch bell nut
, piston ring, set of Teflon Seals, 6 Manifold gaskets, 2 Exhaust gasket
, set of Brake pads.
New in box value for all, over $300.
Used extra parts: Custom manifold, built to use with restrictor, Piston pin, Piston head, Drive chain, 3 Carburetor float pins, floats and float bowls, Spare clutch with clutch bell and assist tools, set of Spare clutch springs, Exhaust x2 and exhaust covers, 2 Stock air filter, 2 Gas tanks x2 and high performance fuel lines, Carb jets #56 #58, Ceramic wheel bearing, 2 Crankshafts, 2 Engine cases, 1 starter case x1, 3 Flywheels, 3 coils for the older 50 motor.
will send pictures, Take it all for only $650. Tom@smallcarcompany.org 203.246.1299
