--> Comer 50cc torque specs – eKartingNews
Home Forums 2-Cycle Racing Comer 50cc torque specs
This topic contains 2 replies, has 3 voices, and was last updated by  Aaron Abed 3 years, 5 months ago.
  • #39831
    Rob Toth
    Just finished are first year in kid karts and would like to check the rings in motor. Does anyone have torque specs for the head any other info that would help out.
  • #40026
    If you want to check the rings do a compression check or look in the exhaust port would be my first action.
  • #40436
    Aaron Abed
    Walt is correct you can get a good idea buy looking into the exhaust port.  If you do pull the head, I torque the Comer C50/51 to 60 inch pounds.   Be sure to use an inch pounds torque wrench.
    Best of luck.
    Aaron
    www.Excel-Racing.com
    info@Excel-Racing.com
