--> Clutch weights – ekartingnews
Home Forums Road Racing Clutch weights
This topic contains 2 replies, has 3 voices, and was last updated by  Jim White 2 years, 5 months ago.
  • #56325
    Joe Payne
    Could anyone tell me if there is a certain ratio or type of track in which the brass or tungsten weights should be used? Thanks for Your Time
  • #56327
    Joe,
    if you have an SMC axle clutch, I might be able to help.
  • #56526
    Jim White
    If you are still looking at building a B stock with Horstmans’ I’m pretty confident the brass will work fine for the tracks around here.
    On my Yamaha sprinter I needed the tungsten to get up the hill at Fernley back in the day. The Reedjet powered sit up pulled the hill just fine with brass.
