--> clutch type – ekartingnews
Home Forums Tech Talk clutch type
This topic contains 6 replies, has 3 voices, and was last updated by  Jeremy Corkran 2 years, 6 months ago.
  • #56318
    Jeremy Corkran
    Hi guys,
    I have an issue with my clutch stall being set too low. In trying to dial in the idle to 1400rpm for my honda 390, it starts activating the clutch. However, the clutch doesn’t seem to have the typical setup with the four adjusment bolts. Can anyone identify the clutch?
  • #56319
    Post a picture and maybe someone can help.
  • #56321
    Jeremy Corkran
    I’m at a loss. I loaded it on Flickr and copied the share address into the picture popup, yet all I get is an image marker, no image. What magic do I have to work?
  • #56323
    Not sure what picture pop-up you’re referring to, but find the link to the photo on Flickr and paste it here in the reply box between the [i*mg][/img] tags, with the * removed.
  • #56333
    Jeremy Corkran
  • #56455
    Looks like a shoe clutch with a spring and a worn out gear. You need a stronger spring to get a higher rpm engagement.
  • #56460
    Jeremy Corkran
    Thank you, Walt. I had a feeling it wasn’t going to be a simple adjustment.
