--> Clone engine gearing – ekartingnews
Home Forums 4-Cycle Racing Clone engine gearing
This topic contains 2 replies, has 3 voices, and was last updated by  Gary Lawson 2 years, 1 month ago.
  • #28244
    Mark Lozon
    Question: Box stock clone jr, will the engine pull off the corners better with a 15 on the clutch or an 18 sprocket ? Some say the 15 allows the engine to build rpm’s faster ?????
  • #28249
    Gary Lawson
    Im sure you are speaking of a 15 v 18 with the same ratio ie 15/60 and 18/72. Oval racers will swear the 18 has better straight speed once you get wound up but the 15 accelerates better. Actual ratio is more important to me but I think the smaller combo does accelerate a little better
  • #28247
    Steen Carstensen
    Yes it will build RPM (not rpm’s :-) ) faster with a smaller sprocket on the clutch. Do the math, 15 vs. 18 is a lower gearing.
