--> Chassis changes for night racing – eKartingNews
Home Forums Chassis & Handling Chassis changes for night racing
This topic contains 5 replies, has 4 voices, and was last updated by  Daniel White 4 years ago.
  • #28685
    Daniel White
    Open practice starts in the morning, and I expect there will be several karts practicing throughout the day.
    Regular practice starts at 4:00. Qualifying starts at 6:00. Heat races start at 8:00. There will be approximately 8 classes running.
    High temp will be in the mid 80s. It will be humid.
    Generally, what changes should I be considering as the rubber is being laid down and the temperatures start to fall (a bit)?
    BTW, I’m in a Tonykart EVR with a Yamaha spec RLV pipe. I’m on used YLCs
  • #28693
    You’ll actually probably be losing grip as the night goes on, not gaining it. Especially if it’s a humid night, you’ll likely see a pretty slick track. The last night race I did was a few years ago but it was humid and there was so much condensation that the karts were actually covered in water every time we went up to the grid.
    Same chassis changes you would do for any normal low grip situation. You’ll want to add grip. Wider front track, stiffer front bar, more caster, narrower rear track.
  • #28697
    Craig Drabik
    I’ve found tires take longer to come in.  I usually add a half pound to a pound between dusk and night runs.
  • #28721
    Good point Craig.
  • #28727
    Matt Dixon
    Take a hard look at adding a tooth after dark
    94y
  • #28749
    Daniel White
    Thanks for all the comments, fellas.
