Home Forums 2-Cycle Racing CASE DOWEL PIN REMOVAL
This topic contains 3 replies, has 3 voices, and was last updated by  Jim Silverheels 4 years, 6 months ago.
  • #22103
    Jim Silverheels
    Got some dowels in a case half that are very stubborn to remove. Heat didn’t do it so I took 1/2 each of ATF and acetone mix and am soaking them for the nite to see if that will do it. Any hints please? thanks chi wa wa
  • #22134
    Clamp the pin in a big vise then twist a little and pull hard.
    What engine is it, some pins were not meant to come out.
  • #22136
    Mike Bray
    There are less expensive ones out there but here’s the concept of a dowel pin puller tool.
    http://store.snapon.com/Dowel-Pin-Puller-Sets-Set-Metric-Dowel-Pin-Puller-11-pcs-6-mm-thru-16-mm–P635477.aspx
  • #22146
    Jim Silverheels
    Giff, it’s a Leopard. The penetrating mixture didn’t loosen them so I put the cases together today without touching the case’s mating surfaces up on my granite block.
