Home Forums General Karting Discussion Carb choice ?
This topic contains 3 replies, has 4 voices, and was last updated by  Jim White 2 years, 12 months ago.
  • #40043
    I have a Tm k9b it has a k9c cylinder,  it has the dellorto vhsh 30mm. Has any tried the pmw 38mm Carb? I seen the electric start Tm k9es uses the  pmw 38mm Carb from the factory, can it be used on the non-electric start engine? any help or Feed back is appreciated
    #40189
    I don’t see how you start the engine would make any difference to the carb. Any time I tried to put a bigger carb on something it just made more problems than it was worth, especially on a small sprint track.
    #40903
    Antonino Esposito
    Yes, It can to be mounted, but I advise carburetor dell’orto vhsh 30mm, it’s right for this engine!!!
    #40905
    Jim White
    A bigger carb may get you a little more top end horsepower it will come at the expense of throttle response. The smaller bore creates a higher velocity through the carb. This higher velocity of air aloows the jets and such to be much more responsive at partial throttle.
