Home Forums General Karting Discussion Cadet kart driver weight and kart Weight.
This topic contains 10 replies, has 6 voices, and was last updated by  Michael Zahorski 2 weeks, 3 days ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • #88307
    Trent Hullum
    I have a 5.2 115 pound 10yr old boy. Does anyone else have a kid around this size driving? What kart do you have and do you get close to the 240 minimum weight?
    I have been wanting to compare karts without engine weights from different manufacturers and can’t find any thing. Man that lack of information in this age of the internet is sad. :{
    (I’m not going to limit my kids diet, Very active in sports year round)
    Thanks for any other advise.
    Trent
    #88350
    Christian Fox
    A cadet kart with a 60cc motor (Swift, Rok) weighs around 140lbs, so at 115lbs. you guys will be a fair bit overweight. You can run without kart graphics and save a couple of pounds, but other than that not much you can do.
    #88362
    Dom Callan
    Do they make smaller gas tanks for cadet karts? I know a guy who did that on his adult kart to save a few pounds.
    #89158
    Jim Maier
    You might try 206 cadet.  4 stroke.  Min weight is 265#
    #89276
    Dan Schlosser
    Most TAG Cadet classes run at 245. Most drivers run at 248-250 to be safe on weight. If you can get to 255 you can compete. With a 90 pound driver and 15 pounds of weight we ran at 248 or so.
    You can hit ten pounds with some basic changes – 3.0 axle (assuming you are running a 5.0 like most current karts), mag front and rear hubs, mag sprocket carrier & engine mount, MXC or the new Swift wheels. Tillett T5 VTi seat is about as light as you can find. No graphics, no data in race trim, no heel stop (shouldn’t need it for a tall driver). May be able to order a kart unpainted. Fastech has a ton of titanium available if you really need an extra pound or two.
    We have made some bigger kids pretty darn competitive – just takes some effort. Pick a good kart and make it light. Don’t pick a kart just for weight.
    #89313
    Trent Hullum
    Thanks for all the responses. I’m going to see if we can shed some weight on the kart $$$
    #89329
    Dan Schlosser
    What kart are you running now Trent?
    #89332
    Trent Hullum
    Intrepid Maky 09
    #89668
    Dan Schlosser
    If you are running the stock axle Trent you’ll be able to save a bunch of weight right from the start there.  The Intrepid has pretty nice vinyl graphics including the floor pan – can save about 2-3 pounds there as well. Are you running the stock cast aluminum wheels? A few of the magnesium wheels will offer a pound plus in savings.
    What track are you running at or which series?
    #89684
    Trent Hullum
    We run club races and a few races around Texas. What axle should I be looking at? I do have the graphics on and we are running mag wheels.
    thanks
    Trent
    #89830
    Michael Zahorski
    Trent,
    What races around Texas will you be running? My daughter runs cadet at our club (HCKC) and in the Texas Sprint Race Series.  It’s a 245 lb min weight for that class in those races, which I believe is also SKUSA’s min for that class. We typically come in anywhere from 247-252 in weight after each race. Race ready, our kart weighs around 160 lbs. right now with 10 lbs of ballast added.  We’ve raced with a few kids that have no problem making weight, and have no weight added to their kart, so you’re not alone.
