--> brake rebuilds – ekartingnews
Home Forums Tech Talk brake rebuilds
This topic contains 3 replies, has 3 voices, and was last updated by  Brian Degulis 4 years, 2 months ago.
  • #22875
    Rick Brown
    How often do you rebuild your brakes? What do you rebuild when you do caliper, master cylinder, both?
  • #22878
    A minimun of every two years and yearly if I can.  Besides replacing the seals in the calipers and master cylindars, also replace the pistions in both.
  • #22883
    Rick Brown
    Do you find that they let go? If they don’t leak do you leave them alone or do you do them as a precaution?
  • #22895
    I flush the fluid ever 3 months or so and only rebuild if somethings leaking. I found keeping the fluid clean prevents problems.
