Home Forums Classifieds Classifieds – Parts Birel Parts for Sale
This topic contains 0 replies, has 1 voice, and was last updated by  Rob Salthouse 4 years, 2 months ago.
Viewing 1 post (of 1 total)
  • #18241
    Rob Salthouse
    Lots of Birel/Freeline parts for sale – all from CR32 (32mm frame). Photos on: http://s1216.photobucket.com/user/robsalthouse/library/Birel%20CR32%20Parts?page=1
    Some photos are a bit fuzzy but if you are interested I can send better ones.
    Note: All parts are Freeline unless stated otherwise. Everything is used. It is in good condition but some parts have normal wear and tear that you get from racing. I’ve tried to show the true condition in the photos.
    I prefer to sell front brakes as “kit” – everything you need to add a front brake system to your kart (e.g. for Rotax Max) but will consider selling individual parts.
    Same with bodywork; prefer to sell as kit – with or without hardware but will split
    Shipping is buyer’s responsibility; I will work with you to find the most cost effective way to ship.
    If you are interested in anything or everything make me a reasonable offer.
    Tie Rod -each $35
    CR32 Front Brake Caliper Assemblies: $300
    CR32 Front Discs (pair): $125
    CR32 Front Hubs (pair): $75
    CR32 Front Spindles Set Left and Right : $125
    Front Brake Master Cylinder, Hydraulic lines and brake cables from CR32: $75
    Complete Front Brake “kit”. Calipers, discs, spindles, master cylinder, brake rods, hydraulic lines, clips etc…from CR32: $650
    KG Unico Side Pods – Used – Pair (red): $30
    KG Unico Drivers Panel – Used (red): $10
    KG Unico Front Nose – Used (red): $30
    Drivers Panel Brackets: $10
    Front Bumper Clips: $15
    Nerf Bars (Unico) set – minor bends on right side bar: $30
    Complete Bodywork kit – all plastic, nerf bars, brackets and clips: $100
    Motor Mount Stop Assembly: $20
    Steering column and hub – CR32 $65
    Steering Column for shifter with Support Assembly & hub – CR32: $75
    Steering Column Support Assembly: $30
    Steering wheel (as shown in photo): $30
    Motor Mount Stop Assembly : $20
    Pedals (left and right) with springs, bushings etc… : $80
    Birel Floor Tray – CR32: $50
    Front Bumper – upper and lower “loops”- CR32(metal): $65
    Exhaust Mount Cradle, used – not Freeline: $10
    Rotax Exhaust Mount, not Freeline –: $40
    Rob Salthouse
    rrksz@yahoo.com
