Home Forums Tech Talk Best Tire Mounting Lube
This topic contains 7 replies, has 7 voices, and was last updated by  Troy Berry 3 years, 3 months ago.
  • #43890
    Ryan Ouellette
    I am looking for some type of spray bottle solution that works good for mounting and dismounting tires.  I am using a Turbo Tire changer.  Any advise on products will be great.
    Ryan
  • #43891
    http://www.supplyhouse.com/Hercules-40-501-Duck-Butter-Lubricant-2-lb-14568000-p?gclid=CP2SsZbyosQCFQ4vaQodEmIAHg
    We use Duck Butter. A tub like this will last you years.
  • #43944
    Rick Brown
    I use dish soap and water.
  • #43945
    Gary Lawson
    Water is not good. Any moisture in the tire will result in more air pressure gain
  • #43952
    Rick Brown
    Never had an issue, tires come up 2-3 lbs over a normal run with douglas LV wheels. I don’t use very much. Wonder if I should try something else? I definitely work under the “if it ain’t broke don’t fix it” theory though
  • #43960
    Jack Cook
    I use simple green.
  • #44007
    Jim Howe
    Any kind of lubricant should work fine, spray or gel, provided it doesn’t have grit or anything else in it that could mess up your bead seal.
    Me personally, I use Vaseline as it makes the tire and wheel very slick so the tire slides onto the wheel easier. And never have had a problem with the bead not sealing.
  • #44775
    Troy Berry
    I like this stuff called Tire Snot. It looks like this, although mine is several years old and I’m not sure if they make it anymore? It last forever, I’ve had mine several years and it’s still good to go.
    https://www.pegasusautoracing.com/bigpicture.asp?RecId=6023
    A search of tire snot leads to this stuff, which looks like it may be a newer version because it has a similar logo!
    http://www.westracingproducts.com/Tire-Snot-Bead-Lubrication_p_206.html
    "The Art is in the details"
    BirelArt AM29 LO206
    Intrepid Cruiser KA 100
