Home Forums Chassis & Handling Bending Yokes
This topic contains 5 replies, has 4 voices, and was last updated by  Evan Fraser 1 year, 2 months ago.
  • #64723
    Evan Fraser
    Hi all, it’s been a while since I’ve been here, been working a lot and had a quiet off-season.  Now it’s a new year with new challenges.
    Walt, maybe you can help me out here..
    One of my yokes is bent to the point that I have to dial in maximum camber to get the tire to stand up straight under load.  I’d like to correct this.  I’ve been devising tools in my head to bend the upper and lower flange of the yoke at the same time while keeping them true without putting an undue amount of stress on the inside of the Kingpin hole.  Obviously I want them to bend at the actual bend at the inside of the flanges.  Does anyone know where a tool to do this can be obtained?  Or have a good design that I can weld together?
    Thanks!
    Evan Fraser
    #43 - Formula K FK01 / Briggs LO206
    West Coast Kart Club
    #64727
    Gary Lawson
    I’ve done it before. Measured them with clippers then used two big crescent wrenches to bend them one at a time. .010-.020″ will change a couple millimeters on the sniper.
    #64732
    Evan Fraser
    Clippers?
    Evan Fraser
    #64759
    Mike Clark
    Probably calipers “Measured them with calipers”
    Spall Chunk prolly ottokorekted
    #64777
    FREDDY SANDOVAL
    Just have some one put it on the table and do it for you
    Most table guys will charge you anywhere from $100, $150 to $200
    And it will work just fine
    Save all your time, frustration, tooling expenses while supporting a local karting shop.
    I know most table guys will show up at most major events to offer their services, as there are lots of bent chassis during the race.
    But if this is not doable then build a tool that will attach to the yoke in place of the spindle with threaded holes at top and bottom, make sure the spacers fit up on top of the yokes, where the camber pills go, then put bolts and washers top and bottom, tighten them up.
    Then weld a very strong handle in the middle for you to pry it down with.
    Good luck, and I hope I didn’t confuse you too much. FastFreddy.
    #64781
    Evan Fraser
    That’s pretty much exactly what I had in mind Freddy.  I actually went to the shops first, no one has a table that’ll do yokes.  I had the frame itself straightened in the off-season at my dealer.
    I may do the caliper and crescent wrench method too, but I’d prefer to keep the yokes as true as possible.  I figure if the force on the spindles can cause the bend in the first place, a similarly shaped tool can bend them back.
    Thanks guys.  I’ll let you know if it works out.
    Evan Fraser
