Home Forums General Karting Discussion Belly Pan Bolts
This topic contains 2 replies, has 3 voices, and was last updated by  Troy Berry 3 years ago.
  • #51187
    How many meat hooks do you have hanging under your kart if you run someone over? Heads go on the bottom on every kart I prepare.
  • #51192
    FREDDY SANDOVAL
    Yup, That’s how I set mine up too, even when you install a new set of chassis protectors, the hardware is designed for heads at bottom, washers and nuts on top.
    Meat hooks, Lol. I like that. You’re funny Walt.
  • #51297
    Troy Berry
    I take it a step farther and buy elevator bolts, and grind the square part down. I also cup them just slightly before install and they sit very flush on the bottom of the floor pan.
    http://www.amazon.com/Hillman-Group-4750-1-Inch-Elevator/dp/B00II5Z860/ref=sr_1_6?s=industrial&ie=UTF8&qid=1436660486&sr=1-6&keywords=1%2F4+inch+elevator+bolts
    I also use a conical washer on top under the nylock nut. They make a good washer and it gives it a nice finished look. They are pretty sweet!
    "The Art is in the details"
    BirelArt AM29 LO206
    Intrepid Cruiser KA 100
