Home Forums TaG Rotax Max Back to karting, Rotax been sitting for 4 years
This topic contains 1 reply, has 2 voices, and was last updated by  Christian Fox 2 years, 11 months ago.
  • #55752
    Joel Pinpin
    I’ll be going back to karting regularly next year but I wanted to do a shake down before the year ends to see how my gear has held up in storage. As far as the engine, are there any absolute ‘have-to-do’ tips before I start up my Rotax after years of sitting in the garage? A friend of mine suggested spraying some WD40 into the cylinder to lube up the piston before I crank her up. Here’s a list of things I can think up to do:
    change crank case oil, replace fuel lines, clean carb and rave valve, reseal exhaust, clean air filter, flush and fill radiator.
    Is there anything I’m forgetting?
  • #55780
    Christian Fox
    I wouldn’t spray WD-40 in the cylinder, I’d just drip a little 2-stroke oil in there. I’d pull the reed cage to make sure they look/feel ok, and while it’s off put a bit of oil under the piston down into the crankcase so the crank gets some oil. Turn it over by hand a few times.
    I would also:
    -take apart/rebuild your fuel pump
    -replace your pulse line
    -overhaul your clutch (at least pull the drum and clean it)
    -Might want to run a little heavy on the oil in your fuel first time out
    Have fun!
