Home Forums Classifieds Classifieds – Parts Axles, belt drive parts, rain tires, rims
This topic contains 3 replies, has 3 voices, and was last updated by  Bryan Williams 4 years, 8 months ago.
  • #21089
    B
    Doing some cleaning out of bins I keep in my trailer. Looking to move some parts hopefully.
    – CRS S88 shifter engine. Full rebuild 6 hours run time top and bottom. All new seals were replaced. Spun lower rod bearing last time out last season. Needs rod and lower bearing. No damage to piston or cylinder. I have a new rod. I have a lot of spare parts for motor. 2 sets of clutch discs, clutch housing, crank side bearing, new rod, new set of reeds, 3 dellorto carb rebuild kits, used but good trans springs/rods, head gaskets, base gaskets, o-rings. Looking to sell as complete package. Carb, pipe, silencer, fuel pump, ignition, etc… Asking $1500 obo for everything.  SOLD!!
    – 4 40mm used axles. Believe they are medium stiffness. Make offer need gone.
    – Set of bridgestone rain tires. Brand new. 2 still in wrappers. Mounted on new Douglas rims. Tires are 6.0×11-5 and 4.5×11-5. Will separate if needed. Never ran. Rims were mounted on kart but never ran. Make offer
    – 7 Belt drive split gears all different sizes. 3 belts in ok condition. 25mm width. Sizes 77, 79, 81 left. $10 each
    – also found a Walbro carb that I have no idea what it is for.  SOLD!!
    I have pictures of everything listed. I will add things as I continue to go through my karting stuff. You can email me at shermab1@hotmail.com or text  for questions or pictures.
  • #21187
    Paul Hir
    Are these YJP? Do you have a ballpark of what you want? Where are you located? I tried emailing you but it bounced it back.
  • #21985
    B
    Tires are YHB.
  • #21988
    Bryan Williams
    Are the axles pretty straight and would you sell 2 for 80 shipped to 93314?
