Home Forums Tech Talk Axle moving during cornering
This topic contains 14 replies, has 13 voices, and was last updated by  Colm O’Higgins 4 years, 5 months ago.
Viewing 15 posts - 1 through 15 (of 15 total)
  • #7180
    JT TT
    Had my axle move twice during my last outing.  It moved part way through the day to the point the rotor face was contacting the inside face of the caliper and dragging.  Got out the allen wrenches and put things back where they belonged, then it move again, albeit, much less.  I didn’t notice the second movement until the kart was on the stand Monday night.
    My question is how tight should I be torquing the bearing set screws on the axle.  Is this an item to check every single run?  I did about 75 laps over about 8 sessions that day.
    Ray Lovestead
    Been there and done that a number of times.  Totally solved it.  Tighten it.
    Seriously though.  What I like to do is, make sure I’m using the same indentions from the previous use, tighten it down really really good, use lock-tight, and voila..  presto.
    The next time you have to remove the axle, clean the spot with a file and then when you re-assemble, hit the same exact spot again, and tighten, tighten, tighten, with lock-tight.
    Done.  Don’t be afraid to indent the axle, in fact, it helps keep it in place.
    "Karting Expert Since 2015"
    Depends on the type of axle, thin wall or thick. For a thick walled axle, position the axle where you want it, remove the grub screws from the axle bearing on one side of the kart. My preference would be the brake side. Drill the axle through the grub screw holes and run a tap that is the same size as the grub screw, through the axle bearing and into the axle. Get longer grub screws and Loctite them in. On the other hand, for a thin walled axle, use a locking collar on both sides of one of the axle bearings.
    Matt Dixon
    Replace your set screws
    Rick Brown
    Clean the axle with some brake cleaner, lock tight the set screws and check them everytime out and you’ll be good!
    JT TT
    I tightened them a lot tighter than I was comfortable doing w/ a 3/8 drive ratchet and they didn’t go anywhere after about 60 laps so I guess that’s not bad.
    Tim Koyen
    They do need to be tightened well.  When I was really into changing axles a lot, I used to strip out an allen wrench from time to time, but it kept them from moving.  I did the Loctite thing for awhile as well, but eventually I just got them tight and didn’t need to mess with it.
    KartLift Kart Stands
    DeepSeat Kart Seats
    Matt Dixon
    Two wraps with electrical tape over the set screws is all you need to keep them from backing out, then no problems removing them when changing axles.
    Martin Colligan
    Prices of set screws are worth changing them when in doubt … I also use axle collars and this helps a lot …
    Roberto Perez
    Just a side note,  Axle moving would also cause your chain to de disaligned and possible damage to your clutch….
    John Savage
    Axle Locking Collars, work great just fit them and you will have no more problems with your axle moving
    Jetting and Kart Set-up Software
    Greg Dzielinski
    Get rid of the bearing set screws and use steel axel lock collars.
    John Gay
    My axle was shifting during this past race weekend and while doing so, it was tighening up my chain to the point where there was absolutely no slack in it.    My kart’s handling was also all over the place too.   The Ny-lock nuts I put on at the start of the season and were unable to keep hold.  I replaced all 6 nuts and also instead of regular washers, I’m using lock washers as well-  got them nice & tight and the problem has not re-occured.
    Jason Bane
    I never felt comfortable getting the set screws that tight, always thought that it couldn’t be good for the axle.  Use axle collars, they work great. Next time you replace a bearing, look into SKF Concentra bearings. They are pricey, but worth it in my opinion. No more set screws to mark up the axle, and when it’s cleaned with brake cleaner and properly installed it will not move. I only have 2, and I use a regular bearing in the middle.
    Colm O’Higgins
    Yep, SKF ConCenta bearings solve this issue and are available in various seal types.  Also see the installation video on u Tube.
