Home Forums Audio/Video Section Aspect Ratio for Creating a DVD
This topic contains 4 replies, has 3 voices, and was last updated by  tony zambos 3 years, 10 months ago.
  • #33965
    I use RaceRender to overlay my RaceStudio data over GoPro video. Since I have a pc that’s running Windows Vista, I take the .wmv file created by RaceRender and run it thru MediaConverter 8 to come up with an MPEG (H264 MP4) file. The MPEG is created because the video is shared with a MAC owner.
    Both the .wmv and the mpeg versions view properly on a pc monitor. Used the .wmv version as the input to Windows DVD Maker. The resulting DVD does not view properly on either a pc or tv. The image is squished from side to side and the top and bottom are cut off.
    What should the aspect ratio be for a DVD and where is it set? Thanks in advance.
  • #33971
    Keymaster
    1920×1080 – that’s 16:9 ratio
    Never worked with the software before, so can’t help you where to set it up.
  • #33974
    Thanks Dave
  • #34011
    James McMahon
    That’s quite a workflow you have there! I think DC is thinking of the HD formats. You can actually get HD video (AVC\Blu ray quality) on a DVD disc if the video is short enough. Of course the player has to support the format that you have chosen too. It’s a good cheap way of distributing HD videos on a disc to people that have blu ray players.
    Anyway, a regular DVD resolution is 720×480. Even though mathematically, this is not 16:9 it is is resolution you need to use for output. A flag is added to the video that makes it display in a widescreen (16:9) format.
    Are you adding menus so forth, or do you just want a DVD playable disk with the footage?
    If you have enough space, have RaceRender make you a near lossless file (huffyUV is a good example) so you get minimum degradation of quality by the time your DVD video is rendered.
  • #34053
    James,
    That worked, thanks. Have tried Windows Movie Maker to add a title and a menu, but isn’t necessary.
    Yea, know that’s a bunch of steps to from a MPEG file back to a MPEG. A SmartyCam would make life easier, but not in the budget.
    Thanks again
